R
Robo
I have an ensuite to wire. The chap wants downlighters in the wall inside the shower cubicle (zone1). The wall is 3inch in depth. Would ip65 downlighters be ok? and would these need to be fite rated or could noraml ones be used as these are not as deep??
He also wants a few downlighters in the ceiling, however its a droma bung and no roof space above. Theres a 20 mm air gab and 100mm of kingspan insulation. Would it be ok to cut a hole in this-Fire hazard?? would fire rated downlighters need to be used. I thought of using LED lamps as these dont get very hot.
ANy help, ideas and links much appreciated. Robo
any1? Pretty pleas
Come on guys, Any1 any ideas?
any1? Pretty pleas
