I feel I should be free to use fuels, and lamps as I feel fit, and should not be forced to use electric or LED, if I want to travel by steam train into the local town, once colvid regulations allow I can do. I know 4000 watt per person will allow one to travel as a reasonable speed, the 250 watt allowed for an e-bike is going OTT in the other direction. For some one like me at 22 stone it means using an e-bike from home is not going to cut it.
But lighting is such a small amount of the energy used, not really worth worrying about, gas cooking wastes far more energy in the home to lights, compare energy for gas hob or oven compared with electric plus the safety aspect between induction hobs and gas hobs yes can see why gas hobs should be banned.
Fluorescent lights with electronic ballasts are around 95 lumen per watt, LED between 75 and 110 lumen per watt, largest problem with fluorescent tubes is a 5 foot tube has a fixed output, it was 64 watt, and this was dropped to 58 watt, which with electronic ballast is around 5500 lumen but were used more for spread of light, so in a corridor 22 watt would have been ample.
As to lighting units with non replaceable parts, it seems to depend on the shape. Where I have a BA22d or E27 holder on the ceiling or wall I can plug or screw in a fitting which has the defuser, LED, driver, zigbee controller, and all the LED's in one bulbous package called a bulb for short, last one I bought, well only one I have bought cost ÂŁ3 from Lidi, and I use it for mood lighting, when it fails I will throw the whole bulb in the bin. On my wall I have a light with like the Smart bulb has every thing built in, but uses a screw to fix it to wall, and a connector block to supply it with power, but in real terms no different to the bulb, except not a screw or bayonet connector.
We have the GX53 bulb holder, it will not take much to make a larger version, which allows lamp change without use of tools. And it seems what they are really saying is the parts which wear out should be replaced with out the need of a tool, but this would also mean the bulk head lamp with a screw to hold the glass on would be banned?
Also people can simply remove the lamp and walk off with it. Some security must be permitted. Even the loo roles are under lock and key.
The biggest problem with LED lights is the smoothing or lack of smoothing, two bulbs, both G9 both with all the control gear built in, this one
has little or no smoothing, and this one
has a large electrolytic capacitor to smooth the output, so does not cause a problem with photo sensitive ailments, but there is nothing on the packaging to identify which is which. Being able to open the bulbous package to see which contains the smoothing capacitor could be an advantage, but would it not be easier to simply force the word smoothed or un-smoothed on the package like with have dim-able or non-dim-able written on package?
