alright lads anyone got any useful tips on finding end of lines on lighting when all the lights are fancy take ages to take off ? im thinking maybe R2 them if they are class 1 fittings ?
thanks in advance !
thanks in advance !
Discuss end of line in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
thanks in advance !
I imagine I have wired the circuit and work it out, after 30 years I very seldom get it wrong, it's not exactly rocket science, sorry but there you are
Put it in limitations.... then take a educated guess and take result or you will spend all day not scratching your head and testing instead..... if the reading is close to permitted values then yes best to find the end of line but if your many ohms clear i wouldn't worry too much.
Reply to end of line in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
