Enecsys Module Compatability | on ElectriciansForums
Discuss Enecsys Module Compatability in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
Noddy67
hi,
I've seen it but can't remember where - the list of which modules you can use enecsys for.
Just installed my first one with Sanyo's but now I look for a mid-range module i can't find what's compatible?
Regards
R
I have the March version of the compatibility list, PM me your email address and I'll send it over if that helps.
whats the proposition with the duos? are they much cheaper or something else?
Reduced fitting time would be odd as they don't take many minutes on thier own but guess Enecsys will lead with some proposition
It appears that the duo inverters won't be released until the end of the year. They seem like something of an improvement to me. A quad inverter would be even better. You know, an inverter that could run sixteen 245w panels would be just great.
Seriously though, I'm not impressed by these inverters. Their efficiency isn't great and they certainly don't look any easier to install than string inverters. Heavily shaded situations only in my opinion.
Discussion with enecsys the other day, duos are available now, and I've got the G83 cert for it, and been quoted for it.
I am still quizzing them whether it actually has two mpp trackers in it or it's a parrellel input, as the cable is a y cable. So unless it's twin core then they must be just parrallel, I've challenged 3 of the people at enecsys over this seeming incompatibility on their statements, and I am still waiting for a satisfactory answer. :(
The site we're using them on 3 roof planes 2 east at different angles 1 south with horrible dormer shading no other sensible choice.
Available now? That's interesting. I spoke to them yesterday and they said they'd be available at the end of the year. Which supplier are you using or are you buying them direct? Do you have compatability information for it?
Worcester - sounds like one MPP for two panels... and as someone joked yesterday the next product would cover four, then sixteen panels and perhaps be so large it's actually stored inside the loft space.
Do you know a price? No actual prices required on this forum but if a traditional SMI 240 is £X, is this £1.5X or similar?
360/200 = 1.8 (or 2 really!) Pricing is 1.46 PLUS you'll save a nominal amount on distribution units, ac bus extension cables and installation time :)
Reply to Enecsys Module Compatability in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
    • Friendly
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
I've always been mildly amused by the pages and pages of calculations for RSJs in domestic extensions and alterations, that accompany my copy of...
