Enlarging downlight holes? | on ElectriciansForums
Discuss Enlarging downlight holes? in the UK Electrical Forum area at ElectriciansForums.net
N
Nicebloke
I know this is something we all come across and in the past when I have needed to enlarge downlight holes, I've used a small plasterboard cutter and even a file. I have about 10 downlight holes to enlarge on an upcoming job so wondered if there is an easier way?
Starrett hole cutters.
[ElectriciansForums.net] Enlarging downlight holes?
Speak to your Electrician he should be able to help.
What would be really handy would be a range of some sort or sleeve that can protect the edge of the plasterboard from those pain in the ..se downlight springs.
With a little bit of patience and fine tuning, one can offer up the new sized hole saw into the existing smaller hole, at a jaunty angle with driver drive initially at slow speed, and cut to the new required size. Moves the centre of the hole a few mm, but easily accomplished.
Reply to Enlarging downlight holes? in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
I doubt we would be recommending them if they were not up to the job
