err 4 on fluke tester | on ElectriciansForums
Discuss err 4 on fluke tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
molly25
Hi i did a loop test before and on my fluke tester is displayed err 4 anyone any ideas what this means?
Hi.
ERR 4 means the fault voltage tolerance has been exceeded, usually caused by testing with kit still plugged in.
You can alter the threshold, not sure how as I dont have one. It should say in the manual.
Meggers have the same problem.
Reply to err 4 on fluke tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Hi, Do you have the user guide. If not I will put the link at the end of the mail. May be worth checking that the meter has been set for UK usage...
