Discuss Error 1 in the Australia area at ElectriciansForums.net
On Site Calibration Services
Mr Mike Olding
01522 703002
He will come to your home or your place of work/site and do it while you wait.
Charged me ÂŁ100.00 to do 2 machines and issue certificates.
I believe he charges about ÂŁ70 ish for one multifunction, he does my flukes for me!
Very reliable.
His Mobile is 07776200146.
calibrating it wont cure this fault, first check the internal fuse if its ok then it needs sending back to fluke, this is the reason i have just binned mine and got a megger, Fluke wanted ÂŁ198 to fix this problem.
Rob
There are two types of error 1, one is a firmware up date and if sent to fluke for calibration they will do. The other is a critical fault and will be the one that costs a load.
Is the unit more than 3 years old because this is the length of there warrenty.
Reply to Error 1 in the Australia area at ElectriciansForums.net
