Ethernet and Power cable to be run underground | on ElectriciansForums
Discuss Ethernet and Power cable to be run underground in the UK Electrical Forum area at ElectriciansForums.net
United Kingdom
Hi,
I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have read that you should not run power and ethernet in the same conduit, so the questions I have are:
What sort of shielded conduit would you recommend for this if I were to run them side by side?
Would it be better to run each one down a different side of the garden?
How deep should I dig down for the cables to be safe?
thanks,
M
Why say that? Both insulation rated to the highest voltage present
If that was the only consideration then that would be fine.
But there is interference to be considered, SWA doesn't have complete shielding due to the gaps between the armour strands. So for particular types or strengths of interference it will not prevent noise in the mains cable from interfering with the data.
It is unlikely to occur in a domestic installation, but not impossible, therefore I say it is unlikely to be an issue.
Very little does have complete shielding, most SY CY is worse than SWA. If the OP is unnecessarily paranoid about that, use a foil wrapped cat 6 but the uplift in cost of that and the equipment would be a waste in this instance IMO.
Thanks to everyone for your help.
I have this for the ethernet: https://amzn.eu/d/dkpy9cX and possibly this for the electrical:
Would these be ok?
M
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Would these be ok?
M
You need to ask the electrician who will be doing the work to calculate what size cable is required for the power.
They will be responsible for certifying the work so they need to make that decision.
Rather than digging two trenches a reasonable compromise would be laying them a couple of inches apart in one trench.
This is what I did a couple of months ago. Trench dug with 8" bucket, SWA laid in direct and green duct for underground Cat5E.
Went along the trench with a length of 4" x 1", pushing the end between cable and duct every couple of metres, turning the wood through 90 degrees to spread them apart and pushing a little earth back in the trench with the side of my foot to keep them in place.
Reply to Ethernet and Power cable to be run underground in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
