Deleted member 26818
So when the burglars break in, they can’t steal them.what's with every body putting those in the lofts .
Manufacture recommended loft position. In my particular case, it's a new build house already completed. So it's a matter of ease of installation with no cables showing. Also the noise of the hardrive/fan running is overcome.what's with every body putting those in the lofts .
Hi, where did you purchase cable from? WasThanks everyone for all the advice... managed to sort one now. ... Pure copper 24 AWG.
Thanks again for everyone’s help
Perhaps I will buy several tomorrow.Hmmm. How much cameras do you have? I think if you are not going to add any more than 4 cameras to the system then you would be able to choose a 4 channel NVR, however if there is the possibility that you may add additional cameras in the future then you would want to future proof your system and choose a larger one, as you cannot add more cameras than channels to an NVR.
I bought it from tvcables.co.uk. It’s a 10 metre pure copper 24 AWG with RJ45 connectors already fitted both ends.Hi, where did you purchase cable from? Was
it on line or local?
I think I may have found a solution....I’m working on using a DNS service (no-ip.com) which will allow me to use a 3rd party application. However if this doesn’t work then I will bear in mind your suggestion thabks for the adviceHmmm. How much cameras do you have? I think if you are not going to add any more than 4 cameras to the system then you would be able to choose a 4 channel NVR, however if there is the possibility that you may add additional cameras in the future then you would want to future proof your system and choose a larger one, as you cannot add more cameras than channels to an NVR.
The way to go would be to purchase an NVR recorder with POE less cables to worry about, run it in cat 5 or cat six. Its more than likely a faulty connection or your IP address, to explain if you do not have a static ip address every time you disconnect your router or CCTV from your router you will loose your connection you will then have to do the port forwarding every time this happens, hope this helps in some wayEvening all.
I have a home CCTV system which I had connected to my broadband router with Ethernet power line adapters. These have recently stopped working and I am looking to replace with Ethernet cable between DVR and router.
It will be running under the floorboards in the bedroom and then coming out the ceiling in the hall and down the wall to the router.
Would appreciate any advice on best type / manufacturer to go for. I don’t want to just buy the cheapest I can get as it will be a PITA to replace when it breaks every 6 months
Thanks in advance
P.S. I wasn’t sure whether to post this in CCTV or computer and networking so apologies if I’ve chosen the wrong forum!
