evening from Scotland- advice if possible. | Page 2 | on ElectriciansForums
Discuss evening from Scotland- advice if possible. in the The Welcome Forum area at ElectriciansForums.net
If it’s only to give the hot water a head start why not only connect one element that way you can switch the rest on when you get there, unless you are jumping straight into a bath on arrival I can’t see any point
Yes broadly you are right, but for paying guests id like to have the hot water available. Thanks
I've just edited your post @Michael Burns to remove your email address from the public forums.
I know it's your choice to post it, but we generally remove them to try and avoid them being scraped by spammers.
The forums have a private messaging facility, so if you've got it enabled (in your profile) one or the other of you should be able to start a conversation with the other and exchange details in private.
Regards
SC
Regards
SC
Cant see how to enable the private messaging, sorry.
Reply to evening from Scotland- advice if possible. in the The Welcome Forum area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
