Everyone makes mistakes, Whats yours ? | on ElectriciansForums
Discuss Everyone makes mistakes, Whats yours ? in the Australia area at ElectriciansForums.net
sparkie710
Everyone will always make mistakes and now we all laugh about them but at the time we just want to go home. So what mistakes have people made here’s just a few of mine loll.
1. When I was an apprentice we was re-wiring houses and that obviously involves lifting single floor boards up. So yea you guessed it not once but twice has my foot fell down and gone throw the ceiling. Least I keep plasterers in their job.
2. Wiring up smoke alarms in a domestic property in the hallway, knocked a massive hole in the ceiling fished a wire across then realized the light didn’t have a permant live.
3. And my favorite, had to replace already wired smokes, and we only saw one in a house. so we replaced that and wired in a new one then realized the smoke originally had a 3 core in it, only realized there was one in the lounge so we replaced that and had to tell the woman that its safer to have 3.
4. Somebody told me a story that they were working in a room doing sockets, and an electrician was in the opposite, then out of the corner of his eye the duvet started moving. Apparently the other guy drilled through the wall, caught the duvet then went to take the drill out and nearly pulled the duvet through as well.
Allow me please to add some of mine.
Fitted a smoke alarm as an apprentice on the landing only to realise that the airing cupboard door would not open as it was too close.
Taking a cover off a 3 phase panel in a distribution warehouse and managed to "drop" the cover right down onto the 125A main switch. You guessed it, bump. Knock all the power off and 3 production lines.
Wired a shower up, nice and quick job. Got a call back the next day to say plumber is doing his fruit in can't fit pipe in. I'd only gone and wired the bleedin' 10mm into the bottom of the shower (you know the one that is specifically for the cold water feed entry). Try the top next time mate plenty of space there.
Pulling a feed through a loft to go back down to mains. Drilled down what I thought was the stud wall. Mate shouts up going mad. Get out of loft only to realise I've drilled through the customer’s nice and new coving. Its ok I said, tissue and some caulk will sort it :)
Working again as an apprentice in some offices retrofitting new lights and breaking into existing circuit. Fitted all the new Tamlite 600 x 600 recessed modular fittings, yeah look nice me thinks. Ok, next job. Boss has gone to do some other job so lets do this quick to impress him. Wire the switch wire, neutral and CPC across the fittings and connect them all up to the PCR's.
Done boss. He says ok and turns them on. Uuuummmmmm why aren't your lights working Tim? I don't know I've connected them all up. He checks in false ceiling. Tim, did you not think to locate the switch wire and interrupt it and connect your new wires?
Ah, that’s why they are not working then :)
doing a CU change, old "tails" 10mm T/E, 8m from Switch Fuse in garage. switch off isolator, disconnect old CU, cut ols tails at CU, remove CU. then temporarily wire socket in garage to isolator for power tools. threading new CU over cables , OUCH. had forgotten to dis. old tails at isolator. DOH.
I dont know about mistakes, but at home i have decided it is easier to do nothing than to do something. If you do nothing then you cant get grief off the wife for doing it wrong.
Cheers............Howard
Go on then I'll add another one for the record. Working again as an apprentice (honestly). Second fixing house and fitting the two way switch up top. Got my cores mixed up and on power up the 2 way did the bathroom light and the landing light was simply a one way. Yes I looked rather red faced when the customer said "I don't think it should do that."
haha im feeling left out, about a year after i started i had a good idea on electrics. and i had to fit a surface pattress for a light switch, for some reason i decided to use a cooker pattress and you couldnt open the door.
Dropping 4 tonnes of scrap iron on to the cab of a wagon (driver wasn’t in it). I was balancing the loads out on a main 4.5MW 440V board. I went in to autopilot and switched No.1 feeder to the magnet cranes OFF because we never used that feeder! The wagon driver ran for his life as the crane ground to a halt above his cab and with no power to the magnet it did a good impression of a Lancaster bomber. The cab was a write off!
Did I get blamed for it? I heard the crash and bangs so switched the feeder back on and legged it out of the fire exit!
My biggest booboo ever. Test and inspection in a laboratory. Went round and unplugged everything to test the ring mains. Later went round and plugged everything back in again except a couple of fridges next to each other. One of the fridges contained an experimental compound which had to remain refrigerated at all times. The explosion completely wiped out the entire building. Everything turned out alright in the end but believe me, I was proper bricking it for a while.
Yay! I’m not the only total numpty on the board! good on you Kamikaze!
I worked out over the years I’ve installed over £35M of gear, and probably wrecked about £.25M with the aid of “development” engineers. They are fun to work with and they have to carry the can when things go wrong!
Famous last words, “told you it wouldn’t work!”
Was doing the testing for a minor works not long after getting out of my time. Being the former apprentice i was given the oldest set of test equipment the company had so when it came to loop tests my meter didn't have the 'no trip' setting. To get by this and being in a rush i bypassed the RCD with a couple of bits of 2.5mm. Finished the testing and yanked the bridging wires out the terminals only for the loose end to swing back straight across the live and neutral blowing the main fuse! The customer was a bit worried when they heard the bang and the black streak made by the vapourised copper was nearly as long as the brown streak in my trousers! :D
I may look like an idiot and talk like an idiot but don't let that fool you. I really am an idiot.
:6:
Your record of ÂŁ25 million will take some beating. The lab cost ÂŁ6.5 million to rebuild. So I guess I will have to accept 2nd place for now.
Reply to Everyone makes mistakes, Whats yours ? in the Australia area at ElectriciansForums.net
  • camperVanGuy101
  • Australia
  • 2
  • 738
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
