Excel CU | on ElectriciansForums
Discuss Excel CU in the Electrical Tools and Products area at ElectriciansForums.net
Hi guys,
I can get a good deal on an Ecel consumer unit. The trouble is that I need to use one 20A Type C MCB as well for a motor circuit. Excel does not seem to do Type C breakers. Will the board be compatible with the other brands like Eaton or some other?
Thanks!
Somebody with the access to a wide range if MCBs shoul make a table for the types of fittings for the breakers. You know which brand can be replaced with which ones.
Would be very helpful info for all of us.
I hate to mention it but did come across one on the net the other day, not sure how accurate/complete it was. I'll see if I can find it.
Edit: have a look under Device Interchangability here: Consumer unit - DIYWiki
No warranty provided though :D
Discussed the other day in another thread
BS 7671 puts specific responsibility on the installer; regulation 510.33 requires that the installer takes into account the
manufacturer's instructions.
It is, therefore, the responsibility of the installer who intends to mix different manufacturers' devices/ components in an
assembly, to undertake appropriate testing and ensure conformity with BS EN 60439. If this is not done then there is a
probability that, in the event of death, injury, fire or other damage, the installer would be accountable under Health and
Safety legislation.
Although devices may appear similar; the dimensions, technical performance and terminations are not necessarily
compatible.
Reply to Excel CU in the Electrical Tools and Products area at ElectriciansForums.net
Crimp or Wago inline connector, my preference would be Wago push fit...
AVR's and Generators in a rack??? And only at 7.5kW?? What are you actually trying to build?
