Dear all
I have been asked to quote for some work at a property and am concerned at the maximum demand already present without me actually adding to it.
I would therefore welcome any thoughts on just how much diversity I can apply.
The consumer unit currently has ten circuits as follows:-
2 NÂş lighting circuits with 6 A MCBs
1 NÂş Immersion heater (assumed to be 3kw) 16 A MCB
3 NÂş Socket outlet circuits 32A MCB
1 NÂş 9kw shower 40 A MCB
1 NÂş Oven Circuit + integral Socket Outlet 32A MCB
1 NÂş Hot Tub, rating plate is 25A but on 20A MCB
1 NÂş Wise Box wireless remote control distribution box, rated at 40A but on a 20A MCB
The incomer is a standard 100A and the consumer unit is a Contactum unit also rated at 100A
The wise box currently has 1 NÂş 2.1kW heater, 1 NÂş 1.5kW heater and a total of 460W of lighting.
The job I've been asked to quote for includes adding another 2.1 kW heater to the wisebox including replacing the feed cable to suit – this would bring the maximum demand of the wisebox to 26 A so obviously a new MCB is also required.
The cooker is being replaced by a new double oven which according to the client needs a 20A feed (probably actually a 4.4kW)
We are also adding a new ceramic hob which according to the client needs a 30A feed. This obviously means replacing the consumer unit with a larger one as we have no spare ways.
My problem is that whilst calculating diversity for the new and existing kit, before I even get to the socket outlet and lighting circuits I am at 134 Amps.
Without the additions I believe we stand at over 100 Amps and again this is without the three socket outlet circuits and the two lighting circuits.
I appreciate the OSG states “The information and values are....only for guidance” and that “the values given in table 1B...may be increased or decreased” but the size of the excess here seems too big for me to claim “I know better than the book”.
I did raise my concerns the issue of maximum demand when I visited – I'm on the verge of telling the customer I can't do it.
Any advice would be greatly welcomed.
Cheers
Ken
Cheers
Ken
