Exhibition Trailer Generator | on ElectriciansForums
Discuss Exhibition Trailer Generator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
North West
Testing 2 exhibtion trailers with the same setup. Power is provided by a generator with a main switch which runs to a consumer unit about 1 metre away. The consumer unit main switch is an RCD, the CU then houses 5 MCB's. Now theres no OPD placed between the generator and the consumer unit but is this a problem?.
4 16A MCB's and 1 10A MCB the generator is easily capable of this load. The consumer unit is fed with 25mm tails. Now BS7671 says overload protection may be placed along the run of a cable within 3 metres which it is. But the only overload protection provided are the MCB's.
Do you see a problem here? What code?. The whole installation is abit of a funny setup, Ive been scratching my head quite a few times with different problems thinking is this acceptable, and just left with this one.
Thanks.
Reply to Exhibition Trailer Generator in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
