Existing REC & house supply | Page 2 | on ElectriciansForums
Discuss Existing REC & house supply in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
just thoughts on this one.
Existing supply to barns from REC,300 amp Tncs 3p,cabling to House,fused of this via 100 amp cutout,by REC
Sub main 16 mm 2 core,to house.
Will the main bonding conductors be the size of the existing supply ie: 300 Amps regarding the neutral.
Reply to Existing REC & house supply in the UK Electrical Forum area at ElectriciansForums.net
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
