G
graeme210375
I have replaced a cu (in readiness for an Elecsa assessment) which is mounted on a stud wall. There is a hole in the wall behind the existing cu where all of the cables enter. As I fitted the new cu in the same location, I left the hole.
I was advised by a Building Control supplied spark that the hole can be filled with expanding fireproof foam and needs to be filled to conform with regs
My question is, does this foam degrade the insulation on the wiring? Or is there a better way of filling the gap?
