P
PLW
Hi there, I understand that a transformer is used to either step up or step down the supply voltage. I know that the basic principle is that if there are more windings in the primary coil than the secondary coil then, the voltage is stepped down and if there a more windings in the secondary coil then the voltage is increased. Please could someone explain the differences between a transformer and an auto-transformer. Also please could you also give examples of their applications and why you would use one over the other. Thanks
