Discuss Exposed copper wire under the floorboards after rewire in the UK Electrical Forum area at ElectriciansForums.net
Just reading the Toolstation flyer that arrived by post offering "18th edtition" Contactum CUs dual RCD without SPD. Really?Haha I was going to say the exact same thing, as soon as you see a BG split load board with no SPD on a new consumer unit you know its gunna be rough... Cheapest consumer unit Screwfix sell.
DIY market , it is huge. A few months ago I looked at a job where the retired home owner attempted his own board change purchased on sale from Toolstation but one of his RCDs kept tripping out. He couldn't find the borrowed N on the lightingJust reading the Toolstation flyer that arrived by post offering "18th edtition" Contactum CUs dual RCD without SPD. Really?
True, but if not fitted there should be a risk assessment to justify it. Which I doubt happens in most cases.1. SPDs are optional,not mandatory.
My gripe is more about the stupid "18th edition" naming. You could argue that "17th amendment 3" makes sense for the metal CU that became a requirement then, but if calling it "18th" then what was added if it is not the SPD?
So whats the problem?.......Just reading the Toolstation flyer that arrived by post offering "18th edtition" Contactum CUs dual RCD without SPD. Really?
This is where a Sharpie is your friend Tel, saves 10 seconds thinking time.another small gripe is the internal tails feeding the RCDs. in the wqy. i usually take them out to wire in the circuis, then refit them after. sometimes i even get them in the right order.
This is where a Sharpie is your friend Tel, saves 10 secondsthinkingDrinking time.
Off topic, but does anyone else sharpie the internal tops of MCB's with the cct details so that you can ident them with the panel off?This is where a Sharpie is your friend Tel, saves 10 seconds thinking time.
I do sometimes number them on the top during an eicr if it's a particularly bad rats nest.Off topic, but does anyone else sharpie the internal tops of MCB's with the cct details so that you can ident them with the panel off?
Genuine question, not a challenge.... apart from the expense, does adding a label internally comply with fire retardancy requirements for a type tested unit?If I'm doing a label print for the outside cover, I normally just do a 2nd label for the bus bar cover inside.
Interesting question!Genuine question, not a challenge.... apart from the expense, does adding a label internally comply with fire retardancy requirements for a type tested unit?
I would say not a problem, as there are already paper labels on the inside of the consumer unit (terminal labels for earth and neutral bars for example).Genuine question, not a challenge.... apart from the expense, does adding a label internally comply with fire retardancy requirements for a type tested unit?
Plenty of 3 phase units have an identical label inside and on the outer cover. Of course they are provided that way by manufacturer so that's a bit different. Just for fun I might try setting fire to a brother label later....
I wouldn't have thought it would provide much fuel for long in a metal unit.
I think a pedant would probably say that the cables are already accounted for in a type test by virtue of the various standards and compliances, whereas the added label has no known BS EN standards materials, adhesive, ink...I doubt that a label makes much difference compared to all the pvc you add when cables are installed.
That probably applies to all the screwdrivers I have left in various panels over the years too.I think a pedant would probably say that the cables are already accounted for in a type test by virtue of the various standards and compliances, whereas the added label has no known BS EN standards materials, adhesive, ink...
The opposite applies too (Confession) - I’ve had a neutral link bar for an Mk split load board in my toolbox for years. I first noticed it after a frantic week and thought ‘someone will phone up and say 50% of things aren’t working’. No one ever did!That probably applies to all the screwdrivers I have left in various panels over the years too.
couple of torches have been lost in the same manor I think.
thankfully they have not caused any spontaneous combustion as far as I know!
Reply to Exposed copper wire under the floorboards after rewire in the UK Electrical Forum area at ElectriciansForums.net
