J
jmc1683
I'm re wiring a ground floor flat, ceiling has been pulled down exposing all the old wiring, some of the worst I've seen, I removed all the cables for the flat I'm working in but one 6mm cable is running through for the flat above, taken from DB in upstairs flat, its joined in 15amp connectors with conductors exposed and live. so question is what do I do here? knock on the door for upstairs and......or what?
