Extending cables in consumer unit | on ElectriciansForums
Discuss Extending cables in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Just after a general consensus.
Do you guys extend cables for the purpose of neatness, even though its a potential weak point or do you accept a shorter cable and accept that its a not as neat?
Regards
if i need to extend cables i would rather use din rail and connectors, at least with an acessable screw connection it can be maintained.
badly crimped cables cause heat (i would crimp small cables but larger cables i would rather not)
Canny piccie there Marvo bonny lad, but I was somehow imaging ye with somewhat darker skin.
and a bone through yer nose. :laugh:
that pic is his son, this is marvo
[ElectriciansForums.net] Extending cables in consumer unit
Just before you all go knocking yerselves and each other out of this, maybe you'd like to read what others have to say on the subject.
It's exactly the same as you'll all be saying - I just though by posting the link it would save you al the trouble!
[NOPARSE]http://www.------.org/forums/forum/messageview.cfm?catid=205&threadid=41987&STARTPAGE=1&FTVAR_FORUMVIEWTMP=Linear][/NOPARSE]
Reply to Extending cables in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
