Discuss Extending cables in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Inline connectors mate ! Push in , pull hard to check good connection ,extend to mcb , nice neat job , no worries .
Only extend them if they aren't long enough, adding joints for the sake of making it look pretty is foolish. Every joint is a potential point of failure.
It's probably been asked before, so apologies if so, but can you get in-line wago type push fit connectors? Rather than the usual ones where the wires enter from the same side? Feel free to tell me to search on the web Daz
These connectors are fine for being used as connections within junction boxes and the like. Used in a CU or DB to extend circuit conductors and would look as if a DIY'er had been at work whether they are electrically safe or not. NO nothing better than good in-line crimped joints as i described above, if you want your installation to look professional....
All very well in an ideal world, pardon the pun.
I like the in line connectors as they are quick, faff free and look better than terminal block or standard 2 port connectors.
Just after a general consensus.
Do you guys extend cables for the purpose of neatness, even though its a potential weak point or do you accept a shorter cable and accept that its a not as neat?
Regards
Does this scenario relate to a CU swap? if the cables are to short to make a decent job then why not install a din rail enclosure adjacent to the CU and make a decent job of extending all the cables.
What can i say, ....from what i can make out here, it'll take too long, it'll add additional costs in both material and time, or just why bother!! It's the time of the new age electrician i'm afraid, where doing things properly comes in at a distant second place to cost cutting and Easy!! ...lol!!
Reply to Extending cables in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
