Extending Immersion wiring
Hi I've to extend the dual immersion wiring both sides , fixed wiring to switch and immersion flex
Usually when extending these loads I double both ends of the wires back and insert wires in the same side and tighten them both under 2 screws. I always assumed this was a better connection than shoving a wire in either side under 1 screw each.
Prefer not to use wagos but just wondered thoughts on this as I've been caught out with an overheated connection on an old job and don't want same happening again
Tia
I dont particularly trust them on high drain loads. I'm not going to get to wagos today anyhow
Just querying my method of doubling up wires under both screws rather than inserting wires each end which I assumed is a better job
Is there a standard flex size for a 2/3 kw dual immersion or is it 1.5 or 2.5
Also I normally confirm resistances when working on dual immersion heaters expecting different readings . I'm almost certain one recently the resistances were the same , I can't recall readings , would there be a dual 3kw model , it was stamped B and S when I opened unit so I went with that anyhow
mickegh,
mickegh,
