Hey all,
I am replacing my old metal Non-RCD protected consumer unit with a nice new consumer unit.
I live in a block of flats and I am in the bottom left of the flats.
I have done all the mounting and recessing that I had to do first.
And I now have it wired up and working but definately not safe and finished.
As I had to mount the consumer unit a bit higher and further right the incoming mains in too short to come into the unit with the SWA sheath all the way into the unit.
So I now want to know how I go about extending the incoming cable safely and so it passes all regulations.
Hopefully you can see from the photos what I mean. You can see the gland on it still from where it went straight into the consumer unit.
I need to extend it only about a metre but it needs to be done.
Also I don't know what size cable it is. Nothing writen on the sheath about size and I guess its 10 or 16mm but I don't know for sure. And its running next too the incomers for the flats above, same type of SWA cable. Main fuses are on the ground floor under the stairs. All have a 60 amp fuse protecting them.
And finally what size earth do I need to run from the steel armour?
Please ask any questions if you need more info.
Thanks so much.
free uploader
Thanks so much.
free uploader
