extending ring | on ElectriciansForums
Discuss extending ring in the Australia area at ElectriciansForums.net
M
martysparky
I have to wire a feature wall. basically the wall has been altered and a double pole switch for a potential lift is now inside a new stud wall (New house).
I want to use the feed from the switch that is on the ring main to feed sockets for the TV and media plus some lighting 200w max.
As access would be awkward to the dry lining box I have been considering crimping the ring main and extending it about 10 inches to S/F/C/U to supply the sockets. Then spur of the F/C/U to another F/C/U to supply the 200w down lights.
Sound ok or is there a better way anyone can suggest?
I did something similar today with crimps. As long as they'd still be accessible (in the back of a socket) can't see there's a problem. Or do you mean losing them in the wall? Would wagos be any use?
I did consider Wago but don't have any and cant get any by tomorrow.
I do have plenty of through crimps though and thought they were maintenance free as can be buried in plaster.
Its just the thought of them being pulled out, as wont be in plaster, but not that its likely.
As I've said in another thread, if the cores you're thinking of crimping are solid, then I wouldn't crimp them. If you can get Ashley maint free JB's tomorrow that would be your best option. If there is any chance of that cable moving and it's crimped, they can come loose, I don't care how good the crimper is. My ratchet crimps are very good, they crimp nice and tight, but if you start moving the cable they do come loose eventually.
Heatshrinked crimps should be fine, in my estimation.
Is this job taking you into or near Newport, I can spare you a few Helacons if you want, but if you want an enclosure to put them in I'm all out. They'll go in a chocbox right enough.
Properly crimped crimps are adequate, though.
Reply to extending ring in the Australia area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
