Extending socket fronts & switches | on ElectriciansForums
Discuss Extending socket fronts & switches in the Australia area at ElectriciansForums.net
E
eskimo39
Hi, a neighour is installing a stud wall over an existing wall to allow sound proofing to be put in between.
They have asked if I can move all their existing sockets and switches outwards to fit on the new wall, however upon inspection there is not enough wire to allow this.
Will I have to quote for a full rewire or am I able to extend the cables using terminal blocks insite the switch boxes, with an additional 8" of cable to the plate?
Any other suggestions would be greatly appreciated.
Many Thanks
Hey Guys..
Im not sure if soundproofing could be a fire risk as in a bit inexperienced at the min as i dont know what its made up of.. But i'd make sure you test the circuit off after the work has been completed just to make sure the joint has little resistance, as a bad joint leads to heat build-up, and with it been surrounded by sound proofing, may slightly be a fire risk. Just a thaught..
If the sockets are on a ring main, you could crimp the end ones and rewire the middle ones and it probably be a quicker job, run new t&e between then at least only 2XS/O,s are crimped.
Lighting i would put on a J/B and put a faster fix dry line box in then if you ever need to get to it again its not a problem, infact you could do that with the S/O,s as well.
Reply to Extending socket fronts & switches in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
