Extending SWA garage cable | Page 2 | on ElectriciansForums
Discuss Extending SWA garage cable in the UK Electrical Forum area at ElectriciansForums.net
Use 6181Y a wholesaler will sell cut lengths including a cpc.
I can get 1m of 3 Core HO7RNF and it is a bit tight behind the board so Id rather have one piece of cable and split it only at both ends. Thanks anyway for the advice
You will then need ferrules and a crimper.
Do I have to use crimps? Can't I just use a terminal strips included in 57A JB and wire it as on the picture below?
[ElectriciansForums.net] Extending SWA garage cable
Reply to Extending SWA garage cable in the UK Electrical Forum area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
But why do they want a CU? That won't give them any more available power than they currently have. As it is a 2.5mm SWA cable it is presumably a...
davesparks
