Hi boys and girls,
Hoping you can advise me utilising some of your experience!
I have a 6a mcb on a circuit that is rcd protected feeding the ground floor lights along with lighting in an extension. Upon changing a bulb (within the extension) there was a flash and the mcb tripped. It was turned back on but none of the extension lights will now turn on, however the main house will and functions normally. I have been looking for where the extension lights are fed from but can't find it? How would you guys go about identifying the source of the problem? Would you use a set process?? If so what would it be? Sorry if this is a very silly question but I'm just learning lol.
Cheers,
Martin
Cheers,
Martin
