Extension socket exploded, problem with extension block or main wiring? | Page 2 | on ElectriciansForums
Discuss Extension socket exploded, problem with extension block or main wiring? in the UK Electrical Forum area at ElectriciansForums.net
United Kingdom
I have a 4 socket extension block plugged in, in my bedroom. Just plugged genuine iPhone charger into it and instantly loud bang and the socket + charger burnt out. Although no damage at the wall socket. I assume this is just a problem with the extension and not the wall / main wiring? Just need to clarify as I know nothing about electrics.
I’ve got three different ones installed(both the new Apple and the old apples ( we have 3 iPads and 3 iPhones in the house) all working ok. I agree that checking the wiring causes them to be disconnected which is a bind.
The main advantage was the removal of adapters and /or additional sockets
Do you find they don't charge as quickly on the usb as with the original adapter?
Depends on the current capability of the USB outlet. Also a lot of chargers these days are dual voltage (9V and 5V), and the 13A socket USB ports don't cater for this (at least as far as I'm aware anyway) so will charge dual-voltage compatible devices more slowly.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Extension socket exploded, problem with extension block or main wiring? in the UK Electrical Forum area at ElectriciansForums.net
