Hi just looking for some advice,
Extension has been built onto the side of a
house and they are putting in a separate consumer unit (just for the extension) and it will be fed off the existing consumer unit with a 16mm T&E. Distance between the 2 boards approx 6 metres. It’s a big enough extension so that’s why they would like their own board.
The existing board mains fuse is 63A.
Would you recommend my new tails feeding the new CU be terminated in with the incoming supply (meter supply into the existing CU ) or come of the load side of the fuse in the existing CU?
Or any other options?
Thanks in advance
Thanks in advance
