Extension | on ElectriciansForums
Discuss Extension in the DIY Electrical Advice area at ElectriciansForums.net
Gingernut
Scarborough
Hi, my son's bedroom has no plug sockets at one side of the room. But I'd like to plug a bedside lamp and some LED lights in at that side of the room. Obviously I can run an extension lead from a socket on the other side of the room.
Would it be an option to run some cable or flex with a plug on, from the socket and attach a double socket at the other side of the room to use?
Any help and advise appreciated.
How is a plugged in double socket better or preferable to a plugged in extension lead ?
Because I already have a double socket, cable and trunking so it saves me ÂŁ20 on a 4/5 metre extension. If it is safe to do and I use the right cable.
[automerge]1586686875[/automerge]
Just wanted to ask the cable to use and the safest and correct way.
Reply to Extension in the DIY Electrical Advice area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
Was there rcd protection on that particular circuit previously
