Thanks for the add. wanting to add an outside light to a house but very limited access and they have only just done up the interior with new carpets etc so don't want to make a huge mess. the only supply near to the location is a spur off the downstairs socket circuit going to a SFCU for a boiler. anything I can do with this supply to get a light up for them? Thanks for any advice offered.
come off the incomer of the boiler SFCU into a 5A SFCU for light. this extra SFCU can be used as a switch for the light, or you can fit an additional switch. also a PIR light is an option.
As long as the spur from the ring is protected by fcu w/13a fuse at its origin you can feed more points from it.
I'd suggest fitting a fcu at the socket the spur comes from then you can do what was suggested above.
Maybe check Zs at the boiler spur to make sure you are not going to fall outside of max values, although this shouldn't be a problem if existing install is of good quality.
Whilst I would agree the above is technically correct, if the spur is definitely only serving the boiler FCU with likely a 3a fuse, then adding a second FCU for a light with a 3a fuse is not going to overload the spur cable. In practice this is no different to a double socket on a spur with two 3a appliances plugged in. That the spur is correctly wired directly off a ring circuit would need to be verified though.
Ayrshire
Exterior light with limited options
Gavin Cameron,
Gavin Cameron,
