Exterior lighting | Page 2 | on ElectriciansForums
Discuss Exterior lighting in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
I have been asked to swap an exterior tube lighting thing to 4 wall lights over a shop front for a friend. My question is what would you guys use for the neatest and tidiest way of splitting the cables e.g. From light 1 to light 2 etc etc? I cant do inside the light fitting as they just have a rubber gromit that would only maintain a seal around 1 individual round cable? I am reluctant to use adaptable boxes as they are so big and ugly.
Any advise or ideas would be great???
Many thanks,
Martin
It is debatable whether silicone affects the properties of the cable sheath as there are so many different varieties. If you need to seal cable entries use a product suitable for electrical work, best to carry out a job to a standard where it is not required at all. You see silicone used all the time when generally it is not necessary.
Well I often tell customers that I need to see the lights beforehand, and that if they don't support loop-in (or at least 2 cables), it's going to cost them extra and/or they'll be having another box on the wall!
Too many lighting manufacturers don't support the prospective installers. I recently grumbled to "DAR" lighting about a 25mm long "junction box" scarcely adequate for a single and very carefully trimmed 1mm cable, and got the unconcerned reply "DAR lighting don't recommend loop-in".
Try and find lights that have sufficient space inside them for two cables....easier said than done though. And preferably ones you could put a gland on. Keep the cable size down to as minimum as possible. Could use a 20mm conduit round terminal box as they are pretty unobtrusive, with a bush and gland on each exit.
Would these work? They are ip68 and I use them for garden lighting where putting in flower beds etc but the could look neat enough for what you're doing.
[ElectriciansForums.net] Exterior lighting
Reply to Exterior lighting in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
