I’m currently converting a Mercedes Unimog into a camper.
The camper body will be supplied with 230V for charging the on-board batteries, and/or running the aircon, which is too much for 24V inverter power.
I’ve chassis-mounted a 3kVA generator, made cheaply by reverse-engineering a portable site generator, fitting it in a chassis box (rear LHS), then duplicating the starter and other controls in the cab and the camper. There’s a changeover switch in the cab to select either generator or ‘shore’ power.
I though this part of the work was finished until I remembered that the 2.5mm SY I’ve used for distributing the mains power is not rated for outdoor use. Oh dear.
So what to use instead? I liked the idea of SY as the braid gives a bit or protection, and it’s very visible for inspection.
What are the alternatives? It needs to be flex as it runs along and between a chassis and sub-frame which flexes, and up into the cab which tilts for servicing. NYY is no good as it’s solid-core.
I can only think of rubber HO7, or blue arctic. Neither of these have much mechanical protection, which, considering the conditions the vehicle will occasionally be used in, is not ideal.
I could fit it in flexible conduit but space in the loom is already a bit tight, and that would also render it invisible for inspection.
Or is SY maybe OK? It’s not like it will be sitting in brilliant sunshine (UV) for years. It’s shaded underneath the chassis area.
What would you do?
What would you do?
