External garage electricity wrongly connected to neighbours supply | Page 2 | on ElectriciansForums
Discuss External garage electricity wrongly connected to neighbours supply in the UK Electrical Forum area at ElectriciansForums.net
Ematthews
Kent
I have found out that my electricity supply in my external garage is wrongly connected to my neighbours electricity unit in their house and their supply for their garage is connected to the unit in my house.
This seems to have been the case since the house was built in 2005 but it has only become apparent now due to their faulty freezer using about 1 months worth of electricity in one day. We then tested our supplies to the garage and when they switched the RCD switch for the garage it cut power to my garage and in my house I cut the power to their garage.
I don’t know the best way to resolve the issue, the garages are leasehold so we have a management company but I’m not sure they will see it as their issue (I have asked the question).
We are a semi detached house and our electricity boxes in the houses are on either side of the same wall. Same in the garage, they are separated by a wall.
Any thoughts or advice is appreciated.
I'm looking at it simplistic that if they are surface wired they must pass through the correct consumer unit through the back and into the other but maybe it isn't that straight forward. Maybe it was done as a joke at the wiring stage hoping it would be noticed when it was tested it just seems too bizarre to be an error, maybe so if all the cables dropped down the same cavity but they don't, they are surface wired.
It’s a strange one, the cables run to the consumer units in the garages, however when they have connected that up to the units in the house, they have mixed them up and the wrong garage is connected to the wrong house.
From your description it would tend to indicated you have a separate unit (CU) in the garage and another (CU) in the house, this would tend to indicate that the mix up was an identification of the supply to the individual garage in the cavity, if so its a simple enough fix.
Hopefully you get along with your neighbour.
Best plan would be to get an electrician in to have a look… it might not be as easy as just moving a couple of cables.
I can’t fathom out how they did it. At no point should the cables from one property enter another.
The number of issues I found just on my street (built 2007) I think I can categorically say that no testing is ever done on a new build.
Yes get along with them well luckily, we are going to call an electrician today, thanks for your reply
Yes that’s exactly right, thanks for your reply, it’s been very helpful
Reply to External garage electricity wrongly connected to neighbours supply in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
