External gas meter | Page 2 | on ElectriciansForums
Discuss External gas meter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi
Yea put your BS 951 clamp before pipe work branches off, we did forget that important bit....
Regards
Correct me if im wrong but im sure in the corgi regs it states that you are not ment to bond the gas inside the gas meter box. How many times have you seen inside the gas box and the gas engineer seals the hole that the gas pipe goes through then Mr electrical comes ago and drills a nice 16mm hole straight in the back of the box to get his 10mm earth cable stick it in the hole and not sealing it???
We have all done it???????????????????
Reply to External gas meter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I like your way of thinking.
loz2754
L
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
