External lighting - am I missing something? | Page 3 | on ElectriciansForums
Discuss External lighting - am I missing something? in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
Situation - local rugby club. Clubhouse has 18 external bulkhead (Phillips) fittings each using 1 G23, 11w lamp; split into two circuits each on 6amp B type mcbs. Both circuits operate via a contactor & photocell.
Problem - one circuit mcb keeps tripping, holds for three/four evenings typically, then trips.
I've swapped the tripping mcb, checked insu res etc; checked each fitting, no obvious probs.
Any suggestions?
Thanks for the suggestion DM. By way of an update, I insulation res tested the circuits to death, checked and remade all the connections at fittings & the sub board and have not had the mcb trip in 10 days. Permanent fix? Only time will tell, but I do know that I have still not found anything that I think may be the cause!
Reply to External lighting - am I missing something? in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
