Hi guys just wondered if the following is acceptable. My customer wants me to run power to his shed from his garage. I fitted the CU in the main house and his garage and all is tested and covered by RCD's however the ground between the two out buildings is concreted and he doesn't want to dig it up to run the SWA that I would usually use. I advised we can go above but he doesn't like the idea of this. Now the third option is to go between the two buildings using some pond flex or similar clipped to the bottom of the garden fence. I've had a brief look it he regs and OSG but I can't find anything to say I shouldn't do this but I just haven't in the past and would like your thoughts on it? Ill take a deeper look tomorrow after work but any suggestions would help. Thanks guys.
PS that shed of course ipad made it she'd
