External shower cable | on ElectriciansForums
Discuss External shower cable in the Australia area at ElectriciansForums.net
M
martysparky
If the only option is to take a shower cable up the outside wall what would be your preference?
New carpet in room above etc no other rout the customer will allow...
Cheers in advance.
Did this for a friend many years ago. I used YT2.
Looked bloody awfull, but its what he wanted:rolleyes:
Galv(properly earthed) or black plastic conduit would probably look best, depending on the house.
Personally I would put the adaptable box on the inside of the house far easier than working at height and then you could use a normal galv one as opposed to a IP rated one.
Thats what I was thinking but to be honest was wondering the best way to deal with the loop of SWA sticking out of the wall in relation to keeping it flat to the wall a the lower end.
Was thinking of drilling downwards from the inside and looping it back round flat like a drip loop but to the side.
You drill the hole then knock a small channel into the brick work where the cable is going to lie makes a curve for the SWA bend naturally round and into the house. Then one cleat near the hole and tighten up should bring it in near enough flush, though always seal the the hole before screwing back or your never get any sealant between the cable and the wall.
Reply to External shower cable in the Australia area at ElectriciansForums.net
Sounds more positive.
You too? I thought I was in a unique position:anguished::coldsweat:
