P
Peter Woodford
Has anyone installed a extract fan that is wired to a stat that if it gets too hot in the room that this will kick in to draw the heat out of the room. this is for a computer hub room in a house
Discuss extract Fan room to hot in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Wire live, neutral and earth to stat and connect as shown on instructions with stat, then take Sw (switchwire) neutral and earth to fan, you need to get a stat with N/O and N/C terminals (normally open and normally closed) that is 230v rated your electrical wholesaler will help you their.thanks darkwood but am crap when it comes to controls plus never done a boiler what is sw and would temp stat need to be 240 v
the power coming in do i go through the stat then to fan or other way around
Reply to extract Fan room to hot in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
