J
Jolyonwag
I need to put an extractor fan in a small downstairs toilet with no window. I know it has to be fused to 3amps and I know it has to have a run over facility, and that it must be linked to the light switch/switch to conform to building regs. It will be a staff toilet and I am aware that people will forget to turn off the light/fan as they leave the toilet, so it could be running all day. For this reason I will probably go for an airflow with a pir detector installed.
I have been reading on the forum about triple pole isolators, fused spurs, and all sorts of different opinions about how to install an extractor fan. My question is: is this correct:
Live feed from toilet light rose to switched 3A fused spur outside the toilet room (1.5 T&E). fuse spur to extractor (L + N only)
Many thanks in advance
