Extractor Fan Wiring
J
jrote1
I currently have a twin and earth cable coming from a fused spur and a 4 core cable going off to an extractor fan. It is a 4 core cable going to the fan as it has two speeds. The switch has a common and L1 and L2 outputs. I have connected all of this fine but how would you recommend connecting the two neutrals together ( the one from the fused spur and the one going off to the extractor)?
Thanks In Advance
Thanks In Advance
assuming you mean the twin from the spur and the 4 wires to the fan go to a transformer? if so then I fail to see a problem, can you give a bit more?
These just need through connecting. Connector block.
I currently have the live of fuse spur going straight into the switch and then the 2 lives in the 4 core going into the switch. I haven't connected the neutral yet. I was thinking of putting a junction box next to the switch would that be a good idea?Thanks in advance
jrote1,
Tiny Spark,
