Faac c721 shorting power on mains | on ElectriciansForums
Discuss Faac c721 shorting power on mains in the UK Electrical Forum area at ElectriciansForums.net
Liverpool
Hi, I have installed a faac c721 with 4 Photocells and everything we connect the transformer it trips the power in the house. We have tested and we get 250v but cannot understand why it keeps shorting the circuit. The c721 is just sat on driveway can't get around it. Has anyone noticed problems with this before - the transformer could just be a smoke screen it's brand new only a couple of weeks old. Faac have said send it back for testing but that's a nightmare with all the blockwork settled back in. I have the nylon racking off also. Any help would be grateful.
[ElectriciansForums.net] Faac c721 shorting power on mains
Is the gate motor unit connected to an existing circuit or a new one?
Is there anything else inside or outside that is also connected to that circuit?
Either way can you identify which MCB on the consumer unit that circuit is.
Have you tried connecting the transformer alone (no secondary connections) ?
What size transformer is it?
Might help to post a picture of the transformer and its connections.
As asked above what is the ir reading L+n to earth?
Hi, it was all 3 on the first test and then 1 RCD and then 2 RCDs on another test. We noticed it was when the transformer was connected that's when it tripped. Plugging everything else in one by one and then pop when the transformer was plugged in.
Your reply seems to suggest that all your "testing" is purely a plug in and wait for the RCD to trip, have you got the necessary test equipment to carry out dead testing and subsquently the live testing
Your profile indicates you are a trainee electrician are you working with someone who is qualified on this job
Hi, thanks we have a fuse switch spare and a safety isolator switch connected to the circuit going from the one right of number 5 on the fuse board. Nothing else is connected to number 5 on the fuse board.
  • [ElectriciansForums.net] Faac c721 shorting power on mains
Hi, yes 100% i am no expert but this was carried out by an electrician and has left it all unplugged - just trying to see for some help. I deal more in access control configuration so my job comes in when the unit is connected and programming it :)
It could be a fault with the secondary wiring - can't tell unless you try it without the secondary connected
It could be transformer inrush, can't tell unless we know the size of the transformer.
It could be the transformer's connected incorrectly, can't tell unless we see a photo of the Connections
It could be an internal fault within the transformer, can't tell without the ir readings
A number of people have asked a few leading questions in order to narrow the issue down, without any response without the information we will not be able to help you.
We can all have a multitude of informed guesses as to the issue, but are unable to narrow it down without the questions being answered.
Reply to Faac c721 shorting power on mains in the UK Electrical Forum area at ElectriciansForums.net
