Discuss Failed Niceic in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Staff member
Admin
Mod
V.Nearly Esteemed
It's the similar threads feature we're rocking. I've stopped it going back further than 3 years. Else we would have this happen on even older threads!
Reply to Failed Niceic in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Therein lies the problem.
I see no merit in further circular debate, so will bow out of this discussion.
It is quite a simple process, if you believe a Hazard exists then an Analysis should be done, if at the conclusion of this Analysis this...
Welcome to the forum and that sounds like an old bulldog switch which was notoriously bad about maybe 2 phases disconnect and the other switch...
Open your eyes and take a good hard look at the electrical industry and you will find it isn't working already, yes we had the NICEIC's defined...
As @DPG says, probably just incompetence. With Blueflame, they seem to be mainly aimed at gas and oil, and I suspect with few members on the...
