Failed socket! | Page 2 | on ElectriciansForums
Discuss Failed socket! in the UK Electrical Forum area at ElectriciansForums.net
Dave64
chesterfield
Hi, in the UK, was vacuuming, did upstairs, went down to the hall, and the vacuum stopped.. checked the fuse, fine.. hit it, plugged it in again, hit it again, plugged it in again. still not working (why do we do this lol)
Plugged it into another socket and it worked... never know a socket to fail.. what's going on there?
Jokey post, but seriously, how does a socket fail?
Thank you guys in advance!
If the plug works in most sockets but not one, then the socket has a problem. If the plug is out of spec as nasty fake one, or been bent by abuse, that could be a factor.
Change the socket for a decent make. If the plug looks at all dodgy, change it as well.
Reply to Failed socket! in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Or just save all the agro and get a proper sparks round for 45 minutes to test the supply cable and re-fit the socket 'properly'
