R
Rob Smith 643
Yo folks,
Not sure that this isn't the second post on same topic, first hasn't appeared. Apologies if so.
Ahead of altering upstairs lighting circuit to add a couple of downlights to an ensuite I carried out the usual tests. Got odd IR results. L-N >1000, L-E >1000, N-E 10!. Did a bit of poking around in the loft and found a spider wired downlight arrangement for main bathroom downlights. JB plus wagos. Removed the arrangement and the IR leapt to >1000. Tested each leg of spider, >1000. As I added eah leg of spider the IR fell away to 10 again. This will be fundamental but it eludes me at present. Any ideas, solutions. Is this typical of spider wired downlights? I tend to daisy chain my own installs.
yours,
Rob
yours,
Rob
