Fan core drill | on ElectriciansForums
Discuss Fan core drill in the Electrical Tools and Products area at ElectriciansForums.net
J
Just
Good evening, I am about to purchase a new SDS drill but today I was fitting an extractor and could have really done with a core drill. A few questions if I may.. Do you think this is man enough as it would be nice to have an allrounder instead of a dedicated core drill? Can anyone better this deal by price or a better drill?
HR2470:MAKITA-MAKITA HR2470 SDS Plus Rotary Hammer Drill
If I need a core saw once a month, can someone recommend a fair quality nicely priced core saw that'll do the job and not break the bank? Should I go for a 110mm for a fan cutout or 105mm if available?
Thanks for the advice.
You need a machine with a clutch if you are to avoid breaking bits of yourself. If a large core bit jams it can break your wrist or throw you across the room or off the ladder
I use one of these for diamond cores
8406:MAKITA-MAKITA 8406 13mm Diamond Core Drill* 850W
And have a large rotary demolition hammer for TCT cores
With regard to size 110mm or 117mm are the best size
For your needs it may be cheaper to hire
Reply to Fan core drill in the Electrical Tools and Products area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
