P
Pinto Baz
I have just been given a periodic test report with a code 4 fault: Bathroom fan not fused at 3A. The fan is fed from the lighting circuit which is supplied via a 6a MCB. Does anyone fuse down fans fed from lighting circuits? Does anyone make a triple pole fan isolator with double pole fusing for timer fans?
It's only a code 4 so I will ignore it, just it's a new one on me!
