Steve 82
Hi guys,
I've got a job with a faulty 4inch fan in a shower cubicle that will need replacing. The problem being at the moment they have a 230v supply there, and the fan is only 2 metres from ground level, not 2.2 metres. So i dont want to replace it with a 230v fan.
Now i know that replacing it with a low voltage replacement with a transformer would be ideal, but the feed is at the light switch outside and i would have to make some damage and a lot of messing around running a new feed from the tranny.
A friend of my has previously instaled a 230v fan that is ok for shower cubicles (apparantly) because it is sealed so that no water can get in. Would i be ok to fit one of these?? Or would i need to go with the low voltage, bearing in mind the flat has a re-wireable fuse board and no rcd protection.
Their not cheap either, i think about ÂŁ60.
Cheers
Cheers
