Fan Isolator switch alternative | on ElectriciansForums
Discuss Fan Isolator switch alternative in the UK Electrical Forum area at ElectriciansForums.net
Darpar
Uk
Hi. Random question, but in our utility room we have an extraction fan like what is normally found in a bathroom. Currently doesn't come on with the light or anything like the bathroom one. It has its own independent isolator switch which leaves the fan on or off continuously. Does this have to be an 'isolator' switch, or could it be changed to a normal light switch type instead? Or a switch with a light to show it is turned on? Thanks
Not really bothered about it coming on with the light in all honesty. Quite like it being a switch on its own. Just looks bit unsightly having a big isolator switch next to a light switch. Wondered really if it could just have a normal switch rather than the isolator type
So it is possible. My electrical knowledge is basic. I'm assuming the isolator works as a switch. So can't see why a light switch wouldn't work instead of the isolator switch?
Because to isolate you need to disconnect both the line and the neutral connections. Standard light switches only disconnect the line.
You can get double pole switches to do what you want.
If there is a 3 core switch cable for the fan you can use a double pole switch with a neon for control,isolation and little light all in one swoop
If there is no 3 core and you only have feed in and switch wire out to fan,you could get your feed off the light switch by changing to a 2 gang grid and use the 2 core as one core for fan switched live + the other core for a neutral for the neon
Photos as requested
[ElectriciansForums.net] Fan Isolator switch alternative
I can't tell you what fan they've got or details of the switch as I've never really paid it much attention. As others say, it all depends...
Reply to Fan Isolator switch alternative in the UK Electrical Forum area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
