Fan Isolator switch alternative | Page 2 | on ElectriciansForums
Discuss Fan Isolator switch alternative in the UK Electrical Forum area at ElectriciansForums.net
Darpar
Uk
Hi. Random question, but in our utility room we have an extraction fan like what is normally found in a bathroom. Currently doesn't come on with the light or anything like the bathroom one. It has its own independent isolator switch which leaves the fan on or off continuously. Does this have to be an 'isolator' switch, or could it be changed to a normal light switch type instead? Or a switch with a light to show it is turned on? Thanks
Sorry. Wanting mk as all others in the house are so will be changing the light switch to match this. Thanks for all your help so far. And thanks for the neon switch option. Is there an option without he neon light? And how will the wiring differ from what I have currently into the new switch?
Yes that's correct. Going to be changing the size glenfiddich light switch to the left to mk logic and wanted the isolator switch to ideally match if possible or as close as can be. Not a big isolator type
Not a clue what happened with autocorrect there! Will be changing the light switch on the left. Hope that makes sense
It's quite simple. Just google
Mk DP switch
Oh, here you are
Click this one instead
Wiring will be the same.
That's great. Thanks for your help. Been looking at the technical info for this type. I don't know which wire is load and which is supply. Any idea how I will. Find out?
Mk DP switch
Oh, here you are
That's great. Thanks for your help. Been looking at the technical info for this type. I don't know which wire is load and which is supply though
If you turn the fan off the live and neutral at the top should be live supply but this will need to be tested.
Simply by using a voltage test device.
I have already given you a link with a DP MK switch without a fuse.
Mk DP switch
Oh, here you are
Didn't you like my suggestion?
Your existing switch doesn't have a fuse, why do you think you now need one?
Use a fused DP FCU if you like.
You can change the fuse in there for whatever value is appropriate, but it's not necessary for a fan on a lighting circuit.
Reply to Fan Isolator switch alternative in the UK Electrical Forum area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
